Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
DIY Cleaning of Toyota Verso Throttle Body
I have a 2007 Touran, automatic 1.8t. It jerks noticeably during acceleration. When idling while parked, the RPM intermittently drops by 100-200, and the car lights dim. What should I do? (I've previously cleaned the fuel injectors and throttle body.)
4Do I need to perform adaptation after cleaning the throttle body?
5Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
6Hey guys, how do you clean the throttle body on your MG3?
7I have a 2015 2.0L automatic model, the second highest trim without a sunroof. The fuel consumption is at 9, which seems quite high. Last year, I had a maintenance check where the throttle body was cleaned, and the spark plugs were replaced. Tires are fine too. The fuel consumption is terrifying—almost 0.7 currency per kilometer. Why is it so high?
8After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
9Hello car enthusiasts, does the 2021 Jeep Compass 1.3T need a throttle body cleaning?
10I've heard that the insurance cost for the 86 and BRZ differs quite a bit. Car owners, can you share how much your insurance is approximately?
