Does the timing chain of a 2013 MG3 need to be replaced? It's only been 100,000 kilometers. Has anyone changed it before?
Do I need to replace the timing chain at 100,000 kilometers?
I've reached 100,000 kilometers. Do I need to replace the clutch kit?
How many kilometers should a timing chain be replaced?
4Is the 2013 automatic Kia Sportage equipped with a timing belt or a timing chain?
5Is the 2013 model using a timing belt or a chain?
6Does the timing chain of a 2013 MG3 need to be replaced? It's only been 100,000 kilometers. Has anyone changed it before?
7What maintenance should be done at 100,000 kilometers? Do the transmission oil and gear oil need to be replaced?
8How many kilometers does the timing chain of a 380 need to be replaced?
9How many kilometers before the timing belt of the Volkswagen Santana needs to be replaced?
10How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
