Any fellow car owners experienced water leakage from the door seal?
Comments( 8 )
How can I fix the water leakage from the A-pillar seal on the driver's side of my Previa?
How to deal with water leakage from the rear spray nozzle of Jimny?
4There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
5Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
6Is there a seal strip installed on the car door?
7Is replacing the weatherstripping effective for water leakage on the driver's door frame of the ACR30?
8Hey fellow car owners, has anyone experienced oil leakage after the car has run over 80,000 kilometers? Any solutions? [Facepalm]
9I'm wondering how to modify the GA6. Any suggestions from fellow car owners?
10Any good ways to remove the water streaks on the car door from the left side mirror after a car wash? Thanks!
