عبدالله عمرو
2019-06-24 19:21
11 MG3, 1.5 AMT version, shakes for a few seconds when starting, then returns to normal. Can any expert explain what's going on?
Comments( 6 )
أحمد معتصم
أحمد معتصم2024-05-30 17:55
Did you solve it, bro?
أحمد معتصم
أحمد معتصم2024-05-29 15:53
I also experience shaking when starting, but it stops after a few seconds or if I give it a bit more gas.
أحمد معتصم
أحمد معتصم2024-05-29 14:10
I have the same issue, not sure what the problem is.
أحمد معتصم
أحمد معتصم2024-05-29 13:55
Is it resolved?
ستار خالد
ستار خالد2019-10-19 12:09
Sometimes there might be a vibration for a second or two, which could be related to the gasoline.
عوض نايف
عوض نايف2019-10-01 21:40
Chain alignment check.
Hey fellow Grand Cherokee owners, the air suspension can rise normally in the first mode, but the second mode just keeps flashing. What's going on?
Does anyone know why the Yashenti dashboard needles suddenly drop to zero while driving and then return to normal after 1-2 seconds? Thanks, everyone.
Is it normal for the trunk to beep a few seconds after closing? The trunk is already locked.
Peugeot 206, 1.6L, automatic/manual transmission, 2006 model. The acceleration is very slow, and when you give it more gas, the RPM goes up, but the speed doesn't catch up. What's going on? Can any experts help explain this? Thanks!
Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
Is the 2016 2.0 Premium version set to not go faster when you press the accelerator at 120? Could any knowledgeable experts explain?
I've had my car for four and a half years and it's only done 36,000 km. It's a 2019 model with the 4J11 engine. Recently, when I start it cold, the engine struggles a lot. The RPM doesn't go up immediately, and the needle wobbles between 500 and 1000 for a few seconds, making it feel like it's about to stall. Then the RPM suddenly jumps to 2000-3000 before settling back to normal idle after a few seconds. There are no warning lights, and once it's running, everything seems normal. I've cleaned the carbon buildup and throttle, and checked the intake for leaks, but the issue persists. I'm not sure what to check next. What should I look into?
The gear shift on the 15 Middle East version of the Toyota Fortuner includes 1, 2, 3, 4, 5, and R. Can any expert explain the functions? Thank you. 🙏🙏🙏
I bought a second-hand 2013 2.0 Peugeot 3008, and I feel like the rear suspension is really stiff. What can I do about it? Going over speed bumps makes people bounce up. Any advice from experts?
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
