Why does the 2016 308 1.2T automatic feel a bit shaky in higher gears? Could it be due to insufficient engine torque? Do fellow car enthusiasts experience the same issue?
2017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
I want to ask everyone, I have a 2022 automatic 86. When shifting from a lower gear to a higher one, there's a bit of a jerking sensation. Is this normal?
The engine noise of the 1.4T Compass is a bit loud, and it's also consuming some oil. How have fellow car enthusiasts dealt with this? Let's share our experiences.
4Hey fellow car enthusiasts, I've switched to Shell Helix Ultra 5W-40 motor oil, but now the acceleration feels sluggish and the idle is higher. Has anyone else experienced the same issue? I was hoping to upgrade to better oil, but it seems to have backfired.
5Why does the 2016 308 1.2T automatic feel a bit shaky in higher gears? Could it be due to insufficient engine torque? Do fellow car enthusiasts experience the same issue?
6I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
7I would like to ask if the stability of the Peugeot 308 1.2T has improved a lot after the 2018 model? Or is it still the same as before, with issues like oil burning and cylinder scoring? Can any real car owners share their experiences?
8The repair shop suggested replacing the upper control arm bushing due to aging, but I found online that it might not be necessary. Any fellow car enthusiasts with experience who can help analyze this? The car has 84,000 kilometers on it currently.
9Every time I accelerate from a stop with my 2.0, there's a sound similar to gears meshing. The dealership says it's the differential noise and considers it normal. Do any fellow car enthusiasts experience this noise as well?
10Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
