When the engine idles at around 2500 RPM with fluctuations of about 500 RPM, but there are no fault codes, what could be the issue? Thank you for your help!
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
4Hello everyone, could someone help me with this issue? When in Park and idling, if I rev the engine above 1600 RPM and then release the throttle, the RPM stays around 1600 for about ten seconds before it drops. This doesn't happen if I don't exceed 1600 RPM. Between 1600 and 2000 RPM, there's a noticeable jolt. Additionally, when shifting gears and slowly accelerating, there's a rattling noise between 1600 and 2000 RPM, but it disappears after 2000 RPM. Does anyone have any insights on this? I would really appreciate it. The car model is a 2016 30T two-wheel drive. Thank you very much!
5When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
6Hey guys, my car is showing error code P048013, which is about fan 1 control circuit, general electrical fault, open circuit. Has anyone encountered this error code before? Thanks.
7Why is the idle speed around 600 to 700 RPM?
8It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
9After refueling my Jetta VS7 at the gas station, the idle speed tends to be high, around 1000 RPM. Then, during driving, the speed fluctuates. After driving for about ten kilometers, the idle speed returns to normal. Alternatively, if I turn off the engine and restart it, the idle speed also normalizes. I've tested this each time I refuel, and it's always the same situation.
10Hi friends, what is the idle RPM for your GAC Emkoo after starting the engine?
