The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
I have a Maserati Quattroporte. Recently, when parked under the sun, the AC blows hot air, but after parking overnight in the garage, it works fine again. This keeps happening repeatedly. Does anyone know what might be the cause?
4My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
5I've got a 2009 Peugeot 307, and the air conditioning isn't cooling very well. I had it recharged with refrigerant, but it still doesn't get cold enough, especially on hot days. Any idea what might be wrong?
6The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
7When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
8I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
9Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
10Hey everyone, the AC isn't blowing any air, and there's no air coming out on internal circulation, only natural airflow. Have you encountered this before? Is it the blower that's broken? I saw online that there could be many reasons. Is it necessary to replace the blower with an original one?
