عبد العزيز عمر
2024-08-16 23:50
I replaced the battery on my 2014 Peugeot 308 and now there's a strange noise coming from the engine. When I opened the hood to check, the noise got quieter after closing it, but there's still a bit of sound. Does anyone know what the issue might be? Thanks!
فهد نور الله
فهد نور الله2024-08-21 23:51
The sound I have is related to the water pump issue, as well as the timing belt set.
سلمان سالم
سلمان سالم2024-08-17 01:02
Check the two belts and the tensioner idler.
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
Does oil leakage from the engine hood of the 2014 Peugeot 301 affect its use?
Is there anyone who knows what's going on with the electric tailgate making a loud and piercing noise when opening and closing?
When the trunk of the Peugeot 301 is opened and then closed, the dashboard makes a ticking sound, similar to the sound of hazard lights. Does anyone know why this happens?
What's going on with the 2014 Peugeot 308 dashboard warning light?
Is it normal for my 2014 Peugeot 308 to have a fuel consumption of 9 liters per 100 kilometers?
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Hello everyone, the power tailgate makes a strange noise when opening and closing. How can I fix it?
Peugeot Peugeot 308
Peugeot 308AED 85,500 ~ 93,900Gasoline & Petrol
