عبدالله قادر
عبدالله قادر
Sep 22
Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
Comments( 10 )
فهد آسيا
فهد آسيا2024-10-31 11:14
I don't think it's burning oil. Here's last year's record: December 2023: Drained 3.5 liters from a 4-liter Castrol, added 3.5 liters, drove 1100 kilometers. October 2024: Used an oil extractor to take out 3.5 liters from a 4-liter Mobil Super, added 3.5 liters.
سلمان حافظ
سلمان حافظ2024-10-30 16:20
Not burnt.
سعود نوح
سعود نوح2024-10-29 09:25
120,000, normal.
حسن موسى
حسن موسى2024-10-20 16:13
My car has reached 170,000 kilometers and still hasn't burned any oil.
أحمد بندك
أحمد بندك2024-10-20 15:34
The engine oil definitely doesn't meet A5/B5 standards.
حسن حميد
حسن حميد2024-10-18 09:44
Nearly 8 years and 60,000 kilometers with no oil consumption... 1.6 naturally aspirated automatic...
حسين هاشم
حسين هاشم2024-10-10 08:30
8w non-burning
سلمان زاهر
سلمان زاهر2024-10-09 23:58
I have almost 100,000 and haven't found any.
حسين رأس
حسين رأس2024-10-09 22:46
They boast so much, but does the Phoenix also burn? My car with 70,000 kilometers is still running perfectly fine.
سلمان لبيب
سلمان لبيب2024-10-09 16:31
Has it been resolved? Mine is overheating too.
Is the jerking in the 13 model caused by needing a transmission oil change? I've never changed it in over 90,000 kilometers. 🤦‍♂️
For a 2017 Honda City with 90,000 kilometers, what type of engine oil should be used? Should it be 20 or 30?
What type of oil is suitable for a 1.4 naturally aspirated manual engine? Is 5W-30 okay?
Does the Peugeot 3008 2.0 naturally aspirated use 5W30 oil?
For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
After the light came on, I drove 20 kilometers and then refueled 65 liters. I'm starting to doubt if my fuel tank is actually 80 liters.
I bought a used 2019 Jetta 1.5L naturally aspirated and have been driving it for a year and a half, but it's only covered 5000 kilometers. Do I need to change the oil now? Which type of oil would be best? Experienced car enthusiasts, please share your advice. Thanks!
How to deal with oil burning? Today, while driving over a bump, the car jolted and the screen displayed a warning: "Low oil pressure, please stop." The warning flashed briefly and disappeared when I returned to a flat road. When I checked the dipstick, the oil level was very low. I just had maintenance done 1,000 kilometers ago. How should I repair this situation with a 1.6 naturally aspirated engine?
Peugeot 308
Peugeot 308BHD 8,500 ~ 10,495Gasoline & Petrol
