2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Is there anyone who has changed the rear shock absorbers because of abnormal noise and excessive stiffness?
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
4Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
5Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
6There are knocking noises coming from the chassis, like "gudong gudong" and "gadeng gedeng". I replaced all 4 shock absorbers, but the noise persists. I checked the ball joints and the steering rack, but everything seems fine. Not sure where the noise is coming from in the Peugeot 301.
7Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
8Has anyone replaced the shock absorber bushings or other bushings on a 2015 Jetta? As for the engine mount rubber, if it's not severely damaged, should I continue using it?
9What could be causing a clunking noise from the left front wheel on a 2013 Peugeot 508 2.3 while driving?
102018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
