سلمان أزهر
2024-08-24 11:38
The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
The self-check light on the Accent's dashboard isn't lighting up? And there's no engine warning light either.
If both the person and the key are inside the car, does the electronic anti-theft indicator on the dashboard still flash normally?
Is it normal for the 2021 four-wheel drive to show an icon on the dashboard with the front wheels tilted, or is it a four-wheel drive warning? The dealer says it's normal, but it didn't seem to be there before. 🤦‍♂️
The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
1.4T engine, when replacing the ignition coil, which OEM brand is good? Any recommendations from fellow car owners who have changed theirs?
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
