محمد محمود
2024-03-23 22:00
My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
نايف فريد
نايف فريد2024-03-23 23:57
My car has a 4AT transmission and it's leaking oil for some reason. When I got it checked, they said it needs to be taken apart, which would cost thousands. They also said I don't need to worry about it for now. I'm not really sure what's going on. Anyway, there's a layer of oil under the transmission casing on the chassis, but it's more like a slow seep rather than a full-blown leak.
Today, the maintenance technician suggested switching to Shell's Yellow Bottle motor oil, mentioning that Castrol's oil with cleaning features might cause more oil leaks. Has anyone used lower-quality oil before? Is it usable?
Pajero V93 chassis is leaking oil, and it's dripping onto the exhaust pipe. It needs repair.
Can a 2009 Peugeot 307 hatchback automatic with 150,000 km go on the highway? I asked the repair shop, and they said it's okay for short distances, but not for long trips.
For the 2014 Jeep Grand Cherokee with a 3.6 engine, the manual recommends using 0W-20 oil. However, the repair shop suggests using a higher viscosity oil.
In 2009 Peugeot 307, the gearbox is slightly leaking oil. The mechanic said that if you want to repair the gearbox, it would cost a few thousand. If the leak isn't serious, you can just leave it and regularly add gearbox oil.
If you have purchased a second-hand 2009 Peugeot 307 sedan with a 1.6 automatic engine and it has run 150,000 kilometers, and you notice that it runs at 3300 RPM at 120 km/h on the highway, you might want to consider changing the transmission oil. It's generally a good idea to check the maintenance history of a used car and ensure that essential fluids like transmission oil are fresh, especially if you are experiencing high RPMs.
I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
RDX, the kettle has been replaced for the third time and it's still leaking. Is it beyond repair?
