My 10-year-old 1.6 manual Peugeot 307 sometimes makes a sharp "squeak" sound, like metal rubbing against metal, when I'm shifting gears, releasing the clutch, or letting off the accelerator. Does anyone know what might be causing this? 🥲
I've got a 10-year-old imported 1.6 Mazda3. Lately, I don't know what's happening, but I can shift to the D gear, yet it doesn't show on the screen. I have to jiggle the gear lever a bit for it to display. Feels like a loose connection. 🤦♂️ Other gears are working fine.
2020 model 1.5L, used for 3 years, just one small issue: there's a strange noise in the back of the car. Not exactly sure where, but it sounds like a spring being compressed or maybe two small metal parts rubbing against each other. Hard to describe... Has anyone experienced this? Any suggestions?
42010 Peugeot 307, automatic transmission. Why does it make a squeaking sound every time I accelerate at low speed and then suddenly release the accelerator?
5If you have purchased a second-hand 2009 Peugeot 307 sedan with a 1.6 automatic engine and it has run 150,000 kilometers, and you notice that it runs at 3300 RPM at 120 km/h on the highway, you might want to consider changing the transmission oil. It's generally a good idea to check the maintenance history of a used car and ensure that essential fluids like transmission oil are fresh, especially if you are experiencing high RPMs.
