عمر زاهر
2024-06-17 12:28
If you have purchased a second-hand 2009 Peugeot 307 sedan with a 1.6 automatic engine and it has run 150,000 kilometers, and you notice that it runs at 3300 RPM at 120 km/h on the highway, you might want to consider changing the transmission oil. It's generally a good idea to check the maintenance history of a used car and ensure that essential fluids like transmission oil are fresh, especially if you are experiencing high RPMs.
How do you guys change the transmission oil for your Ruixing? I changed my transmission oil at 200,000 km, and now it's almost 260,000 km. When I accelerate at low RPMs, there's a noticeable jerk and drag, like it's getting stuck.
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
How do you guys change the transmission oil, gravity or circulation?
My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
Have you ever tried running 12,000 kilometers before changing the engine oil?
In 2009 Peugeot 307, the gearbox is slightly leaking oil. The mechanic said that if you want to repair the gearbox, it would cost a few thousand. If the leak isn't serious, you can just leave it and regularly add gearbox oil.
If you're considering buying another car and your annual usage is around 5,000 kilometers, with a budget of 80,000 RMB, you have several options. Since you like the appearance and interior of the Peugeot 508, you might want to look for a good condition second-hand Peugeot 508 within your budget. Additionally, you could explore other compact or midsize sedans that are known for their style and comfort. Make sure to check the vehicle's service history and condition if you're opting for a used car to ensure a good purchase.
How many kilometers should you typically change the transmission oil?
