I've got a 2009 Peugeot 307, and the air conditioning isn't cooling very well. I had it recharged with refrigerant, but it still doesn't get cold enough, especially on hot days. Any idea what might be wrong?
My 06 S40's air conditioning sometimes doesn't cool. It has refrigerant, and sometimes it works. The technician said it might be an electrical issue, while others say it could be a problem with the AC motor. Could anyone help me figure out what's wrong?
Is your mini air conditioner not cooling very well? Does anyone else have the same issue with their car?
Is your air conditioning cool enough? Other cars can go down to 16 degrees, but I feel like the Swift only goes down to about 22 degrees. It's not very cool, but not too hot either. 🤦♂️
4Hello everyone! I need some advice. When I turn on the AC, only the driver's side vents blow cold air, while all the other vents (passenger and rear) blow hot air, and it's really hot. Even when I close the vents, the area around them is still really hot. I went to the dealership, and they said I need to add refrigerant.
5Hey folks, is your Kamiq's air conditioning cool enough? Mine is just not working well.
6If you have purchased a second-hand 2009 Peugeot 307 sedan with a 1.6 automatic engine and it has run 150,000 kilometers, and you notice that it runs at 3300 RPM at 120 km/h on the highway, you might want to consider changing the transmission oil. It's generally a good idea to check the maintenance history of a used car and ensure that essential fluids like transmission oil are fresh, especially if you are experiencing high RPMs.
7My 2009 Peugeot 307 won't start. When I try to start it, the engine doesn't respond, and there's just a buzzing sound. Does anyone know what could be wrong? The battery was replaced not long ago.
8Cayenne steering wheel noise: When the car is cold, there's no issue; it's very smooth. After driving for a while (around 1 hour), especially in hot weather, there's a squeaking noise when turning the wheel. Do any fellow car enthusiasts have the same issue? I saw on a social media platform that it might be the airbag clock spring?
9I've got a 2009 Peugeot 307, and the air conditioning isn't cooling very well. I had it recharged with refrigerant, but it still doesn't get cold enough, especially on hot days. Any idea what might be wrong?
10I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
