علي نواف
2023-11-07 17:10
I'm wondering if a 2012 Peugeot 307 with 130,000 km needs a timing belt replacement. Is there anyone who hasn't replaced theirs since the 2000s?
Comments( 12 )
عباد علي
عباد علي2024-05-06 11:47
The 06 hasn't been replaced yet.
عمر مكي
عمر مكي2024-04-28 09:35
Did you replace the timing?
علي نواف
علي نواف2023-11-28 09:55
Thank you, Tu Hu checked and everything is fine.
زيد عمر
زيد عمر2023-11-26 20:33
My used car has 170,000 kilometers and I just changed it.
عبدالله جم
عبدالله جم2023-11-26 15:05
Need to be replaced.
محمد شادي
محمد شادي2023-11-21 23:56
When the time comes, you need to replace it. Otherwise, if the belt breaks down on the road, the loss could be significant. [666]
علي فارس
علي فارس2023-11-21 22:15
It's best to replace the timing belt and water pump together at 80,000 kilometers.
خالد شهيد
خالد شهيد2023-11-17 18:35
You're really awesome! [Thumbs up]
حسن رأس
حسن رأس2023-11-13 22:53
Hurry up and change.
فهد مروان
فهد مروان2023-11-13 01:51
You should replace it every 50,000 to 70,000 kilometers. If the timing belt breaks, it can cause severe damage to the engine.
The heated rearview mirror isn't working, but the electric adjustment is fine. I've been to several repair shops, and they all say I need to replace the base, which costs over 2000 for an original one. Any experts here who can give some advice? Thanks!
Is there anyone who has replaced the 2012 XV's dashboard with the 2016 high-end version? Any recommendations?
How to modify the brakes on the Peugeot 207, brothers? Can it use the same parts as the 307? What parts need to be replaced?
When driving at 60-80 km/h, I hear a buzzing noise coming from the front of the car. It gets a bit better when I speed up. I initially thought it was a bearing issue, but after replacing it, the noise is still there. What could be the cause? Could it be the belt, transmission, or something else? (The car has 130,000 km on it.)
1.4T engine, when replacing the ignition coil, which OEM brand is good? Any recommendations from fellow car owners who have changed theirs?
My 2009 Peugeot 307 won't start. When I try to start it, the engine doesn't respond, and there's just a buzzing sound. Does anyone know what could be wrong? The battery was replaced not long ago.
It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
