Hi everyone, I've got an '07 model practice car. When I turn on the internal circulation switch, the light comes on, but there's no circulation effect. What's going on?
Hi everyone, the steering wheel buttons on my C30 can't switch songs, but the volume control works. What could be the issue? I've installed a navigation system.
Hi everyone, is the charging cable plug that comes with the car 16A or 10A?
Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
4Hi everyone, I've got an '07 model practice car. When I turn on the internal circulation switch, the light comes on, but there's no circulation effect. What's going on?
5If the external circulation of your car's air conditioning system can't switch to internal circulation, it might be due to a problem with the actuator or a control switch. The cost for repair can vary depending on the make and model of the car and the specific issue. I recommend consulting a local mechanic for an accurate diagnosis and cost estimate.
6Hi everyone, Suzuki SX4 owners, which button is for switching music?
7Hello everyone, I recently got a 2020 Jeep Compass 1.3T. Can anyone tell me how to turn on the daytime running lights?
8I'm not sure? When the internal circulation light is on, does it mean the internal circulation is off or on?
9I want to ask the experts, why does the air conditioning not work when I turn on the internal circulation? The light comes on briefly and then goes off, but the heating works fine. Why is that?
10Hey everyone, the AC isn't blowing any air, and there's no air coming out on internal circulation, only natural airflow. Have you encountered this before? Is it the blower that's broken? I saw online that there could be many reasons. Is it necessary to replace the blower with an original one?
