Can a 2009 Peugeot 307 hatchback automatic with 150,000 km go on the highway? I asked the repair shop, and they said it's okay for short distances, but not for long trips.
Comments( 15 )
The oil light came on while driving the 2012 XV at high speed. I went to the repair shop, and they said it's burning oil. What should I do?
My GAC GS7 has only run 55,000 kilometers, and the turbocharger fan is already broken. The repair shop said it might just be a one-time issue! Have you encountered anything like this?
4My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
5I bought a 2017 V40 and recently the engine sounds like a tractor when running. Does anyone know what might be going on? The repair shop said it might be a cylinder scoring issue, but they're not sure.
6In 2009 Peugeot 307, the gearbox is slightly leaking oil. The mechanic said that if you want to repair the gearbox, it would cost a few thousand. If the leak isn't serious, you can just leave it and regularly add gearbox oil.
7If you have purchased a second-hand 2009 Peugeot 307 sedan with a 1.6 automatic engine and it has run 150,000 kilometers, and you notice that it runs at 3300 RPM at 120 km/h on the highway, you might want to consider changing the transmission oil. It's generally a good idea to check the maintenance history of a used car and ensure that essential fluids like transmission oil are fresh, especially if you are experiencing high RPMs.
8My 2009 Peugeot 307 won't start. When I try to start it, the engine doesn't respond, and there's just a buzzing sound. Does anyone know what could be wrong? The battery was replaced not long ago.
9I've got a 2009 Peugeot 307, and the air conditioning isn't cooling very well. I had it recharged with refrigerant, but it still doesn't get cold enough, especially on hot days. Any idea what might be wrong?
10Purchased in March 2010, it's a 2009 model with a 1.5 automatic elite trim. It has been driven for 150,000 kilometers, is in good condition, and has had no major repairs. How much is it worth now?
