2010 Peugeot 307, automatic transmission. Why does it make a squeaking sound every time I accelerate at low speed and then suddenly release the accelerator?
2010 Changan Yuexiang, experiencing body vibration at low speed and low RPMs. The symptom disappears at higher speeds. What could be the issue? Is it the valves or are the engine mounts worn out?
Whose car would behave like this, suddenly losing power while accelerating and then gaining speed again?
What is the top speed and 0-100 km/h acceleration time for the Genesis G70?
4I'm wondering if a 2012 Peugeot 307 with 130,000 km needs a timing belt replacement. Is there anyone who hasn't replaced theirs since the 2000s?
5Can the low beam headlights of the 2010 Peugeot 207 be adjusted for height?
6During driving, the 2016 Peugeot 301 makes a loud scraping noise from the undercarriage. It happens once every few miles. Sometimes it occurs when turning or braking, but most of the time it's quiet. What could be the issue?
7Why does the Ford Territory suddenly lose power and then accelerate again multiple times when normally accelerating to 60 km/h?
8My 10-year-old 1.6 manual Peugeot 307 sometimes makes a sharp "squeak" sound, like metal rubbing against metal, when I'm shifting gears, releasing the clutch, or letting off the accelerator. Does anyone know what might be causing this? 🥲
92010 Peugeot 307, automatic transmission. Why does it make a squeaking sound every time I accelerate at low speed and then suddenly release the accelerator?
10I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
