Will disconnecting the battery for a long time in a 301 cause damage to the ABS pump? [Cheers]
Does playing in the snow with an F150 cause a lot of damage to the car? [crying emoji]
Is it true that the battery of the 720s needs frequent charging? I heard from others that if the battery is disconnected, the 720s won't function properly. Is that true?
What could cause high water temperature if the water pump and thermostat are not the issue?
4Yesterday, the rain and snow caused the handbrake to freeze, and now the ABS light is on. Any good solutions? Will it get better when it warms up?
5Is anyone experiencing CarPlay connection issues, like it keeps disconnecting automatically? What's causing this?
6Will disconnecting the battery for a long time in a 301 cause damage to the ABS pump? [Cheers]
7Does installing a supercharger on a 2700 engine cause any damage to the car?
8After disconnecting and reconnecting the battery, the navigation unit went black. Why is this car so fragile? Ugh.
9Can the 2016 imported Outlander be disconnected from power for a long time? I saw online that it might cause data loss.
10Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
