When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
The clutch of my 2018 Foton Tunland E5 was recently replaced, but there's always a burning smell while driving. Additionally, there's a strange noise when I'm not pressing the clutch, which disappears when I do press it. What could be the cause of this?
Is there a strange noise when the car starts, but it goes away once driving? Does anyone know what this could be?
There's a noise coming from the transmission, but when I press the clutch, it stops. The dealership said it's an issue with the clutch disc, and they've already replaced it. But the problem still isn't solved!
4When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
5My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
6When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
7The engine of the 2014 GS5 is making a squeaking noise. What could be the problem?
8I need some help. I have a 2019 MG HS 1.5T, and it's run for 37,000 kilometers. The engine pulley makes a squeaking noise when I release the accelerator, and it also makes noise when I turn on the AC. What should I do? I just replaced the alternator pulley, but it didn't help.
9What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
10There is a squeaking noise when the steering wheel of my 2008 Kia Sportage is turned all the way. What could be the problem?
