حسين زكريا
2024-03-25 20:11
There are knocking noises coming from the chassis, like "gudong gudong" and "gadeng gedeng". I replaced all 4 shock absorbers, but the noise persists. I checked the ball joints and the steering rack, but everything seems fine. Not sure where the noise is coming from in the Peugeot 301.
عبد العزيز طل
عبد العزيز طل2024-03-28 22:58
The "gudong gudong" sound might not be from the chassis. Try removing everything from the car, including the spare tire, and see if the noise is still there. As for the "gezi gezi" sound, you'll need to judge it more specifically.
Why is there always a strange noise coming from the chassis?
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
Is there anyone who has changed the rear shock absorbers because of abnormal noise and excessive stiffness?
Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
Looking to purchase two rear shock absorbers, removed from a modified Vito.
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Peugeot Peugeot 301
Peugeot 301AED 59,900Petrol
