محمد راضي
محمد راضي
Mar 17
Is the clutch very heavy? Do I need to replace the clutch kit, or should I replace something else? Or is this normal? It's a 2014 model with over 200,000 kilometers, and I just got it as a used car.
حسين خالد
حسين خالد2024-08-07 12:28
Change it as soon as possible; it's thicker and saves on fuel.
سعود بهاء
سعود بهاء2024-03-22 14:24
The tire noise on this car is quite loud. I recommend driving for a while and then switching to Continental silent tires. It'll feel like a completely different car.
سعود بهاء
سعود بهاء2024-03-22 14:23
Why did you switch to the Haval H6?
سعود بهاء
The owners of this car probably don't visit forums often. The clutch itself is heavy, and the clutch travel is particularly short, so it takes some getting used to.
محمد راضي
محمد راضي2024-03-17 23:14
Has anyone else encountered the same issue with their car?
I've reached 100,000 kilometers. Do I need to replace the clutch kit?
Do your car's wheel bearings break easily? I just replaced them 3,000 kilometers ago and they're broken again. Is this a common issue with this car model, or could it be caused by something else?
MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
Is the clutch on the 207 particularly high? Should I replace the clutch kit, or is this normal for the car?
Kia Cerato 2018, manual transmission. I've replaced the clutch kit twice, but the clutch still feels heavy. It's almost 90,000 km now. How do you guys solve this? 😩😩😩
The car stopped in the middle of the road, with 25,000 km mileage. Couldn't shift gears, and the clutch felt heavy. Surprisingly, it was fine the next day. Decided to replace the clutch slave cylinder for 240 RMB. 🤷‍♂️
Anyone got a carbon fiber kit for the GV80? I need a set.
I've got a 2014 Peugeot 3008 1.6T that's been burning oil. I've added three liters of oil in the past 5000 kilometers. I'm thinking about replacing the valve seals. Does anyone know if this works? Has anyone else done this, and how effective was it?
I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
Peugeot 301
Peugeot 301BHD 6,000 ~ 6,995Gasoline
