حسين زكريا
حسين زكريا
Mar 17
I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
خالد فريد
خالد فريد2024-09-07 13:00
The car runs fine on flat roads but makes noise on rough roads.
حسين زكريا
حسين زكريا2024-06-25 15:26
I found the reason: the stabilizer bar bushing was worn out. Added a layer of motorcycle inner tube, and it solved the problem perfectly.
سعود رضوان
سعود رضوان2024-04-06 20:08
Is the steering wheel turned all the way?
عبد العزيز طل
عبد العزيز طل2024-03-28 23:04
Specific problems require specific solutions. The "gudong gudong" noise isn't necessarily from the chassis. Try removing everything from the car (including the spare tire) and then test drive to see if the sound persists.
نايف نور
نايف نور2024-03-18 11:18
Did you hit the undercarriage? I deformed the connecting rod under the engine, which caused vibrations. After I replaced it, everything was fine.
How does the C40's variable damping shock absorber chassis perform?
Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
Hey guys, the dust boot on the control arm ball joint is torn. Is it necessary to replace it? Will it have a big impact if I don't?
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
There are knocking noises coming from the chassis, like "gudong gudong" and "gadeng gedeng". I replaced all 4 shock absorbers, but the noise persists. I checked the ball joints and the steering rack, but everything seems fine. Not sure where the noise is coming from in the Peugeot 301.
I have a 2017 Haima S5 manual 1.5T, and I'm facing some issues: the car door is rusted through, there's a noise from the chassis (note: I've replaced the lower control arm, ball joint, steering gear, and engine mount but still can't find the problem), and the USB port inside the car has poor connection. Is there anyone experiencing the same issues? Any solutions?
The accelerator feels weak, and the control arm is making a rattling noise.
What causes the steering wheel to make a noise when turning the shaft?
The steering wheel is crooked 🤦‍♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
Peugeot 301
Peugeot 301OMR 5,500 ~ 6,000Gasoline
