فهد بشر
2022-12-04 00:48
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
حسن عبد له
حسن عبد له2024-03-30 00:34
Damn, I encountered the same problem. Sure enough, it won't start.
نايف أبشير
نايف أبشير2023-02-21 00:33
Here's a secret for you: Regardless of the model, even those Peugeot keys that don't fold, you don't need to worry. On Taobao, you can get an original key for around 90, buy two, then pay a deposit of over 300 to use a machine. You can adapt it yourself at home. Then you'll have the original central control! No need to go to the 4S shop. Once you're done, return the deposit and get it back, no worries! 😁
حسن زبيدي
حسن زبيدي2022-12-10 10:19
Without the chips, of course, it won't start. Without the chip sensors, there's no way it will start.
عبدالله ثمين
عبدالله ثمين2022-12-04 06:23
Can the key turn when inserted? Replacing the chip inside only controls the locking mechanism and doesn't affect the ignition.
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
When the Peugeot 206 automatically locks while driving, but then immediately unlocks, and this cycle repeats every time you start moving, what could be the reason for this behavior?
I bought the 2022 GAC GA6 in May this year, and the remote key's automatic unlocking function when approaching the vehicle is gone. Does anyone know why?
My Peugeot 301 manual from 2016 has trouble starting when it's cold, but it starts easily when it's warm. What's going on?
Can't start the Peugeot 301, can I still use the air conditioning? Also, what is the password for the central control screen?
Has anyone replaced the key battery before? After I replaced the car key battery myself, I can remotely lock and unlock the doors without any issues, but the car won't start when I insert the key. The anti-theft system isn't connecting. Does anyone know how to solve this?
If the remote control function of your Peugeot 307's key is not working, even though the key itself is in good condition, what could be the issue?
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
What could be the reason that the remote key can't lock the car? When I press the lock button on the remote, I hear two clicking sounds, and then it automatically unlocks. I'm desperately seeking answers from fellow car enthusiasts. 😬
Peugeot Peugeot 301
Peugeot 301AED 59,900Petrol
