Has anyone changed their transmission fluid? How many liters did you use? Did you do a gravity change or a full cycle change???
How many liters of oil does a Mazda 2 automatic transmission take for a gravity oil change?
How do you guys change the transmission oil, gravity or circulation?
Hey car enthusiasts, at how many kilometers did you change the transmission oil for your Territory?
4Has anyone changed their transmission oil? How many liters did you use, and did you do a gravity change or a complete flush?
5Has anyone changed their transmission fluid? How many liters did you use? Did you do a gravity change or a full cycle change???
6Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
7How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
8Hey guys, how many liters of brake fluid do you need to replace the fuel?
9When did you all change your transmission oil, and at how many kilometers?
10How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
