حسن قاسم
2020-01-22 21:09
Even after replacing the spark plugs, camshaft sensor, and cleaning the throttle body, my 2014 Peugeot 301 is still having trouble starting. Any ideas on what could be the issue?
Comments( 8 )
سلمان جلال الدين
سلمان جلال الدين2024-04-08 17:39
How did you solve it? I just encountered this issue!
عبدالله ثمين
عبدالله ثمين2022-09-12 09:25
Ignition coil?
حسن زبيدي
حسن زبيدي2022-09-11 13:39
How can you feel the impact of carbon buildup on power?
أحمد معاوية
أحمد معاوية2022-09-11 11:22
How did you solve it? I have the same issue as you.
أحمد نظيف
أحمد نظيف2020-03-07 09:50
Check the fuel line.
حسن قاسم
حسن قاسم2020-01-22 21:33
When starting the car, it feels like the fuel supply is not sufficient, but it quickly returns to normal. There's no impact on normal driving.
حسن قاسم
حسن قاسم2020-01-22 21:30
But the fuel filter has already been replaced.
أنس عبدالله
أنس عبدالله2020-01-22 21:27
It's likely that the issue is with the fuel filter. The fuel might be clogged, leading to insufficient fuel pressure. You should also check the fuel lines and clean them.
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
DIY Cleaning of Toyota Verso Throttle Body
Do I need to perform adaptation after cleaning the throttle body?
Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
Hey guys, how do you clean the throttle body on your MG3?
Has anyone experienced gear shift jerking after just replacing the spark plugs and cleaning the throttle? It was fine for two or three days, but then the jerking returned.
What kind of engine oil is suitable for a 2014 base model manual Peugeot 301?
Hello car enthusiasts, does the 2021 Jeep Compass 1.3T need a throttle body cleaning?
Peugeot Peugeot 301
Peugeot 301AED 59,900gasoline
