حسن خليل
Oct 17
When the water temperature in your 3008 1.6T rises from 60 to 90 degrees, releasing the accelerator to around 1200 RPM causes a squeaking noise. After the water temperature rises to 90 degrees, it suddenly drops to 70, and when it rises back to 90, the noise disappears. However, you notice a burning smell like electric wire insulation. Additionally, there's an issue with the air conditioning—it sometimes fails to cool, and you have to restart the engine to get it to work.
I want to ask, I bought a new car and have driven 2000 kilometers, the car is overheating, and the water temperature gauge shows 90 degrees. How can I solve this issue?
Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
4The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵💫 Do any other T-Cross owners experience this situation?
5How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
6I have a used Suzuki SX4 AWD with 130,000 kilometers. In extreme cold weather (minus 40), it drives very steadily. However, when the temperature rises to around 5 degrees above zero, it feels a bit floaty and unstable at speeds of 80 to 100 km/h. Can fellow car enthusiasts offer some advice?
7What is the situation with the abnormal noise from the water pump of the Jetour X90 Wilderness Edition 1.6T? Is it normal?
8I recently got a 2013 1.4T VW Touran with 110,000 km on it. It's been owned by one person before me. Currently, the big electric fan isn't working, but the small one still is, and the water temperature isn't high. I'm planning to replace it in a few days. The only issue right now is a whistling noise in 5th gear at 70-80 km/h. It doesn't happen in 4th gear, only in 5th when I accelerate, and it stops when I release the gas. 🙂?️ Seeking advice from experts—is this a transmission problem?
9Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
10Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
