When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
Hey fellow car enthusiasts, my Lancer's fuel gauge is below the red line, but the fuel light isn't on. I can only fill up 37 liters, but isn't this supposed to be a 50-liter tank? Has anyone tested this?
Does anyone know why the water temperature gauge on the 2020 Jetour X70 with 1.5T engine sometimes shows six bars and sometimes five bars? I've already replaced the thermostat, but it still doesn't work.
4I filled up the tank a week ago, and the displayed range hasn't changed. Is the sensor broken, or is it the fuel gauge float that's faulty?
5What could be the issue if the fuel gauge is empty, you fill up the tank, and it still doesn't respond?
6When the fuel tank is full, it shows a range of 302 kilometers. What could be the reason for this?
7The fuel tank capacity of a Jetta is generally around 55 liters. If you're filling up about 57 or 58 liters each time, it could be due to the fuel already in the tank or variations in pump measurements.
8When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
9For the 2015 Peugeot 3008, the fuel gauge was previously inaccurate, and the fuel tank got dented. After replacing the charcoal canister and the gray filter, the fuel gauge is still not accurate, sometimes showing more and sometimes less.
10What is the fuel tank capacity for the 2016 model? I had about 50 km left and when I went to refuel, the pump stopped at just over 40 liters.
