حسن ممدوح
2024-09-01 14:23
When the air conditioning is turned on in the 3008, it triggers an alarm, but it goes back to normal when the AC is turned off. What could be the problem and how can it be resolved?
Does your e2 air conditioning compressor make a strange noise? I feel like the sound is a bit loud, and it comes and goes. The salesperson said it's the sound of the compressor when the air conditioning is turned on. Can anyone help me check this?
My car's alarm goes off for no reason when it's parked, and after the alarm goes off, I can't lock the doors with the remote key.
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
How do I turn off the alarm on the Multivan? When I'm lying in the car, the alarm goes off after a while.
For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
For the 2019 GS5270T model, if the vehicle randomly triggers an alarm as if someone is trying to open the door without a key, but no one actually does, and it happens multiple times a day, how can this be resolved?
Does your Santana's engine shake when you turn on the air conditioning for cold air?
Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
Peugeot Peugeot 3008
Peugeot 3008AED 99,900 ~ 209,900Gasoline & Hybrid & Petrol
