احمد حسين
احمد حسين
Oct 2
Peugeot 3008 windscreen washer not working? I've already added three bottles of fluid.
سعود فرج
سعود فرج2024-10-06 23:02
Check if there's any sound when the washer sprays. Also, see if there's water flowing near the wheel hub. If there is, open the engine compartment and check the left side near the hood edge for a black tube. See if it's broken, bent, or leaking.
علي زياد
علي زياد2024-10-06 09:15
Me too, I'm currently using a mineral water bottle to water [666].
نايف أنيس
نايف أنيس2024-10-05 11:59
Same here, maybe the motor is broken, no sound [I need some peace]
ستار عمر
ستار عمر2024-10-04 14:22
The delivery pipe is broken, and you can see it as soon as you open the hood.
خالد عَبْدُ الله
خالد عَبْدُ الله2024-10-04 10:00
The motor might have burned out.
Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
What brand of power steering fluid should I use for my Peugeot 3008 2.0L naturally aspirated engine?
Has anyone experienced the fast charging port opening by itself after parking and locking the car? I've noticed it happening three times already.
Has anyone reprogrammed the transmission on a 2014 Peugeot 3008? I'm considering it but worried it might not work well. How's the experience?
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
What could be the reasons for the Peugeot 3008's automatic start-stop function not working properly?
I've got a 2014 Peugeot 3008 1.6T that's been burning oil. I've added three liters of oil in the past 5000 kilometers. I'm thinking about replacing the valve seals. Does anyone know if this works? Has anyone else done this, and how effective was it?
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
Peugeot 3008
Peugeot 3008KWD 7,100 ~ 15,541Gasoline & Hybrid & Petrol
