عبدالله بكران
2024-07-02 09:27
Is there a good way to insert the airbag clip under the driver's seat after it's been removed? It's really hard to put back in.
I want to install an armrest. How do I remove the armrest on the driver's seat? Any advice, folks?
I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
Where should I insert the USB drive in the Hongqi HS7 to play music? I've tried both the slot under the dashboard and the one at the back, but it shows "USB not mounted". What should I do?
If you want to go on a road trip and put a custom mattress in the back, how's the space? Can the air conditioning stay on continuously? According to the video review, it seems like the power cuts off automatically if there's no one in the driver's seat?
How do you secure the clip under the rear seat of the HS7? It's always coming loose.
Is it necessary to put a protective film on the black Zeekr 001? Guys, the expensive ones seem not worth it, and I'm worried the cheaper ones might be hard to remove later. How did you guys decide?
Any good ways to remove the water streaks on the car door from the left side mirror after a car wash? Thanks!
How do you remove the rear seat cushion of a Taurus? I've managed to release the two front clips, but I'm not sure where the hooks are in the back where it meets the backrest. If any fellow car enthusiasts know, please let me know. Thanks!
Peugeot Peugeot 3008
Peugeot 3008AED 99,900 ~ 209,900Gasoline & Hybrid & Petrol
