فواز سعود
فواز سعود
Oct 5
I've got a 2014 Peugeot 3008 1.6T that's been burning oil. I've added three liters of oil in the past 5000 kilometers. I'm thinking about replacing the valve seals. Does anyone know if this works? Has anyone else done this, and how effective was it?
علي زياد
علي زياد2024-10-06 09:15
I also have a 2014 3008. Mine doesn't burn oil, and I change it every 10,000 kilometers.
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
My 207 keeps burning out the starter motor. In the past year, I've already replaced two, and today it burned out again, even started smoking. It feels like just replacing the starter motor isn't solving the root problem. Any fellow car enthusiasts know how to fix this?
Has anyone replaced the door seals? How's the effect? The wind noise is getting louder.
Is the third-generation 888 engine, with 70,000 kilometers on it, now burning one liter of oil every 5,000 kilometers? I've always used Castrol Edge 5W40 oil. Does it need a major overhaul?
I've been driving a 2009 Kia Sportage manual GLS with 120,000 km on it. I've always used 5W-30 engine oil, but recently it seems to be burning oil a bit. Should I switch to 5W-40 oil for maintenance? Has anyone experienced this before and can share some insights?
Has anyone added a seat subwoofer, and how is the effect?
I just got a 2015 model with a 1.6T engine. What type of oil should I use? Anyone know?
2013 Peugeot 3008 1.6T version is consuming coolant too quickly, but no leaks can be found. Does anyone know what might be going on?
Peugeot 3008 windscreen washer not working? I've already added three bottles of fluid.
Peugeot 3008
Peugeot 3008KWD 7,100 ~ 15,541Gasoline & Hybrid & Petrol
