I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
I feel like the headlights aren't bright enough, especially the high beams. Do any fellow car enthusiasts know of any parts I can replace them with?
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
4I replaced a pair of LED bulbs on my car, but now the low beam and high beam look the same. Any tips to adjust them to be lower?
5Hey guys, has anyone successfully replaced the halogen bulbs with LEDs on a 301? Is it something I can do myself, not too difficult? Could you share a link? Thanks!
6I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
7Can the daytime running lights be replaced separately? I modified the headlights, and it seems like the daytime running lights got damaged; their brightness isn't enough. It's a 2009 model.
8Could you recommend a car light? I feel like my current ones aren't bright enough.
9I'm driving a 2013 Sunny with a manual transmission, high trim. The halogen lights really don't seem bright enough. I checked on Pinduoduo, but I'm hesitant to buy from there. Has anyone bought lights from there? Can any of you guys recommend something you've used? Driving at night is tough; oncoming high beams make it hard to see anything. 🙈 Can you recommend some good combined high/low beam lights?
10If you're planning to replace the LED lights on a 2013 Kia Sportage yourself, you'll need to know the specific model of the LED lights required. It’s best to consult the vehicle's manual or check the existing LED bulbs for their specifications.
