Hello everyone, when I start the car and reverse while turning the steering wheel, does anyone hear a noise from the lower control arm? It goes away after a while! My car has done 110,000 kilometers. The engine also makes a rattling noise when starting, and the RPM is over 1000, but it settles down in a few seconds! I suspected the chain, but since the RPM is also high, I ruled that out! Has anyone experienced something similar?
What's the idle speed of your Mazda 3 when starting cold? Mine is over 1000 RPM.
Why does my 2008 imported Mazda 3 hatchback idle at 1200 RPM during cold starts, while it's usually at 1000 RPM? How can I fix this?
Why is my S40 idling at 1000 RPM, and how can I bring it down?
4Do you also hear noise from the engine while inside the car?
5When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
6Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
7Hello everyone, when I start the car and reverse while turning the steering wheel, does anyone hear a noise from the lower control arm? It goes away after a while! My car has done 110,000 kilometers. The engine also makes a rattling noise when starting, and the RPM is over 1000, but it settles down in a few seconds! I suspected the chain, but since the RPM is also high, I ruled that out! Has anyone experienced something similar?
8Does your car have this kind of noise? The engine is making a strange sound. I suspect it's the VTC gear making noise.
9Hello fellow car enthusiasts! I'm having an issue with my car and would like to seek your advice. The check engine light is on, and it's hard to start the car (it takes a while to start). Once it starts, the RPM is normal, but as soon as I shift gears, the RPM immediately jumps to over 1000, almost 2000. When I shift back to Park, the RPM slowly returns to normal. I've already replaced the throttle, and it worked fine for two days, but now the same problem is back. Has anyone else encountered this? What could be the issue?
10Hey fellow car enthusiasts, do you also notice that when you start the car in P gear, the engine revs quite loudly, usually above 1000 RPM? But once you shift to D gear, it drops below 1000 RPM and the sound gets much quieter. Is that the case for you too?
