أحمد صعدة
أحمد صعدة
Sep 1
French car enthusiasts, I need your help. My 2.0 engine is making a strange noise. When I accelerate gently, there's no issue, but when I accelerate sharply, there's a "da-da-da" noise at around 2000 RPM. After a few seconds, when the speed picks up, it goes away. There's no noise above 3000 RPM, only during sharp acceleration. I bought it second-hand and didn't notice this sound before. If it's not a big deal, I'll just keep driving it for now. [Yeah][Cute][Cover face]
خالد معتمد
خالد معتمد2024-09-03 05:20
When my car was cold before, pressing the accelerator also made a "da da da" sound. Later, it turned out to be an issue with the timing chain.
عبد العزيز عباس
عبد العزيز عباس2024-09-02 16:38
It's likely that your water pump is broken or the timing belt needs to be replaced. I had the same issue before, and after replacing them, everything went back to normal.
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
When will it be introduced? Once it's here, I'll trade in my 2017 Highlander right away. 😁😁😁
When the RPM reaches 2800, there's a loud roaring noise, but after 3000 RPM it disappears. What's going on? [Cover face]
Can you hear the engine making a "da da da" sound when accelerating your ASX?
What's causing the noise when accelerating in a 2015 S5 with manual transmission, when the RPM doesn't match?
What causes a jerking sensation when gently pressing the accelerator?
Hello everyone, when I start the car and reverse while turning the steering wheel, does anyone hear a noise from the lower control arm? It goes away after a while! My car has done 110,000 kilometers. The engine also makes a rattling noise when starting, and the RPM is over 1000, but it settles down in a few seconds! I suspected the chain, but since the RPM is also high, I ruled that out! Has anyone experienced something similar?
Hi everyone, can someone help me out? Today, I suddenly noticed a noticeable "da-da-da" sound from the engine when it goes above 2000 RPM. What could be the issue?
Peugeot 3008
Peugeot 3008EGP 330,000 ~ 2,401,300Gasoline & Hybrid & Petrol
