علي فخر دين
2024-08-12 11:46
For the 2015 Peugeot 3008, the fuel gauge was previously inaccurate, and the fuel tank got dented. After replacing the charcoal canister and the gray filter, the fuel gauge is still not accurate, sometimes showing more and sometimes less.
خالد صعب
خالد صعب2024-08-13 17:21
Does it burn oil?
Does the Navara have an anti-theft filter in the fuel tank?
Recently, my fuel tank cap often won't open. Sometimes hitting it with my fist works. Any guidance, please? Thanks!
Hey fellow car enthusiasts, my Lancer's fuel gauge is below the red line, but the fuel light isn't on. I can only fill up 37 liters, but isn't this supposed to be a 50-liter tank? Has anyone tested this?
Does anyone know about the 2013 ASX 1.6 manual having issues with fuel tank overflow and carbon canister leakage causing the car to stall?
I filled up the tank a week ago, and the displayed range hasn't changed. Is the sensor broken, or is it the fuel gauge float that's faulty?
What could be the issue if the fuel gauge is empty, you fill up the tank, and it still doesn't respond?
When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
2018 model, two-door F56, there is a continuous and noticeable thumping sound from the right rear of the vehicle at idle. I've checked it myself, and when I unscrew the fuel cap, the sound stops immediately. Once I put it back on, it starts again after a while. If I cover the fuel cap with my hand, the sound stops right away, but once I remove my hand, it starts again. I suspect it has something to do with a component related to the fuel tank, perhaps the charcoal canister or the fuel tank vent? Anyone knowledgeable can help? I feel like I'm close to solving the problem, can someone assist?
Is anyone aware if the Prado will be redesigned next year? I just hope for a larger fuel tank, less hard plastic in the interior, and some changes to the trunk. No other demands. [crying][crying][crying]
Peugeot Peugeot 3008
Peugeot 3008AED 99,900 ~ 209,900Gasoline & Hybrid & Petrol
