عبدالرحمن أنس
2024-06-02 11:41
Does the Peugeot 3008's automatic door lock still allow the doors to be opened from the inside? Is this normal? What solutions are there? Otherwise, it really doesn't feel secure.
محمد أرسلان
محمد أرسلان2024-06-14 20:39
French cars are all designed like this.
عبد العزيز عباس
عبد العزيز عباس2024-06-14 15:28
Child lock
عمر علي
عمر علي2024-06-10 01:01
If you don't want to enable the child lock, there's no solution. That car will make it so you can't open it from the outside or the inside [I want to be alone][I want to be alone][I want to be alone]. Might as well not have doors then [I want to be alone][I want to be alone].
عبدالله عبد القادر
عبدالله عبد القادر2024-06-02 13:33
To make the rear doors unable to open from the inside, you need to activate the child lock. The hassle is that every time someone gets out from the back, the driver has to get out to open the door.
عبدالله عبد القادر
عبدالله عبد القادر2024-06-02 13:31
Most cars should be able to open, right?
Peugeot Peugeot 3008
Peugeot 3008AED 99,900 ~ 209,900Gasoline & Hybrid & Petrol
