حسين سا مرعي
2022-07-30 20:02
Dear car enthusiasts, my little lion is a 2015 Peugeot 3008 premium version, and recently the fuel consumption is quite high at 11.6. It struggles to accelerate to around 80 km/h, even when I floor the accelerator. Does anyone know what might be causing this?
Comments( 8 )
عبد العزيز دليل
عبد العزيز دليل2024-08-28 04:30
Did you turn on the cruise control? [I want to be alone]
عبدالرحمن سعيد
عبدالرحمن سعيد2024-07-04 20:27
The problem was resolved after replacing the throttle.
سعود فرج
سعود فرج2024-07-03 00:21
Did you fix it, bro?
عبد العزيز جم دين
عبد العزيز جم دين2024-05-02 12:23
Is it a high-pressure fuel pump?
سعود شعبان
سعود شعبان2024-04-27 20:58
My 2.0 also has this issue, at 80 km/h the throttle makes a muffled sound and doesn't accelerate [I want to be alone].
عبدالله طموح
عبدالله طموح2022-08-12 11:45
There are many possible reasons for this issue. I recommend going to a repair shop for a check-up.
عمر تركي
عمر تركي2022-08-01 22:33
Throttle.
عبد العزيز أبشير
عبد العزيز أبشير2022-07-31 09:43
Check how long it's been since the transmission fluid was last changed.
2014 Peugeot 3008, 2.0, experiencing shaking between speeds of 60 and 80 km/h, similar to engine stalling. What might be the issue?
My Mitsubishi ASX struggles to go beyond 140 km/h on the highway, even with the pedal almost to the floor. The RPM is between 2600-2800. Usually, when driving, the accelerator feels a bit sluggish. Does anyone know what could be the reason?
For a 2015 diesel Grand Cherokee, besides the original engine oil, what other options are suitable... Also, recently when I floor the accelerator around 2000 RPM, there's a whistling sound. Have any fellow car enthusiasts experienced this?
Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
For the 2015 Peugeot 3008, the fuel gauge was previously inaccurate, and the fuel tank got dented. After replacing the charcoal canister and the gray filter, the fuel gauge is still not accurate, sometimes showing more and sometimes less.
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
Peugeot Peugeot 3008
Peugeot 3008AED 99,900 ~ 209,900Gasoline & Hybrid & Petrol
