سلمان إدريسي
سلمان إدريسي
Jul 16
Why did the designers decide to place the rear wheel arch on the rear door? The car's length has increased significantly, so why is the position of the rear wheel arch just a few centimeters different? This is a bit unusual.
علي أزهر
علي أزهر2024-07-16 07:41
There are also the Tank 300, old BJ40, new BJ40, and the five-door Jimny, which all have split rear fender flares with half on the door.
عبدالله حميد
عبدالله حميد2024-07-16 07:39
Prado, Highlander, RAV4, Crown
عبدالله حميد
عبدالله حميد2024-07-16 05:09
It's not that special, right? Aren't the Pajero and Black Warrior like this too?
Choosing between the McLaren 570S, Audi R8 Performance, Lamborghini EVO RWD, and Porsche 911 Turbo S can be tough as they're all great supercars. Here are a few things to consider: 1. **McLaren 570S**: Known for its lightweight design and exceptional handling. It's a great choice if you value driving dynamics and a unique supercar feel. 2. **Audi R8 Performance**: Offers a mix of everyday usability and supercar performance, thanks to its Quattro all-wheel drive. It's a good choice if you want a reliable and comfortable ride. 3. **Lamborghini EVO RWD**: Provides an exhilarating driving experience with its rear-wheel drive. It's ideal if you're looking for something that's both thrilling and a bit raw. 4. **Porsche 911 Turbo S**: Known for its incredible acceleration and all-around performance. It might be the best fit if you want a blend of speed, comfort, and practicality. With a budget of 3 million, you have some flexibility. Think about what you prioritize most in a supercar—whether it's handling, comfort, or outright performance—and that will guide your choice.
I have a 2012 Jeep Compass. Recently, when I turn on the AC, there's a clicking sound coming from the glove box area, but it stops after a few clicks. Also, when I'm turning at low speeds, it feels like the rear wheels are stuck, causing the car to vibrate and the rear wheels seem to be rubbing or bouncing on the ground. Has anyone experienced similar issues?
I want to ask, why is the front brake caliper of the Taycan positioned at the front? Isn't it said that for mid-to-high-end cars, the front wheel calipers are generally positioned at the rear? Please explain.
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
Why does the rear-wheel drive option come with a lock, but the four-wheel drive doesn’t?
Why does the newly purchased car make a slight noise when moving forward with the left rear wheel, but not when reversing?
1.8L 2017 automatic luxury model with just over 50,000 km on the odometer. It's a red car with quite a few scratches on the exterior. It had a front-end accident but only needed a front set replacement, no damage to the frame. The right rear door has some bodywork done. However, the engine, transmission, air conditioning, and car system are all in excellent condition. You can test it out before deciding. It's a great choice for practice driving.
Why doesn't such a big car have rear-wheel steering?
BAW 212
BAW 212KWD 9,954 ~ 10,081Gasoline
