سعود نواف
2024-06-13 11:14
Hey guys, when is the release date? The launch event basically just announced the car, and then nothing else happened... [Facepalm]
عمر عبد له
عمر عبد له2024-06-13 23:09
It won't take too long. The hype will die down soon. You can probably order the car by July.
What happened to the guy who had issues with the VIN number in the previous complaint? I'm hesitant to buy this car because of it. [facepalm][facepalm]
At extremely low speeds, there's a crisp sound from the relay contact when kinetic energy recovery engages. In creep mode, it occurs just when the brake is applied during low-speed crawling. Without creep mode, it happens when you release the accelerator at low speeds. It's just one crisp sound, coming from near or in front of the pedal. The sound is very faint, and can't be heard with the windows open, music playing, or on a bumpy road. This is with the first launch of the dual-motor. Has anyone else encountered this issue, and can it be fixed?
Hey guys, I just got my driver's license. Would you recommend getting a used NV200 to drive?
Hey folks, I pressed the hill descent control on my 2014 Koleos, but nothing happened. What's going on?
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
Hey guys, what's the actual weight of the vehicle on the registration certificate? Is it really over 1.7 tons? Is this small car that heavy? [facepalm]
Hey guys, is your app working? Mine keeps showing that it can't export data and nothing works.
Hey guys, need some help! Has anyone experienced the car suddenly braking on its own? The dashboard shows braking, but there's nothing in front.
Hey guys, does the VS7 model released in September 2020 come with a particulate filter?
BAW BAW 212
BAW 212AED 69,000Gasoline
