The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
The dashboard always switches to miles automatically. Sometimes the wiper gets stuck when pressed once, then resets after pressing again, and only wipes once after another press. When enabling the lock car beep, the keyless entry is overly sensitive, resulting in a series of beeps. 😔 Does anyone else have the same issues?
During driving, the 2016 Peugeot 301 makes a loud scraping noise from the undercarriage. It happens once every few miles. Sometimes it occurs when turning or braking, but most of the time it's quiet. What could be the issue?
4The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
5Regarding the issue where the 360-degree camera system doesn't activate when reversing, but works fine when the turn signal is on, how can this be resolved?
6I've had my KAMIQ for 1.5 years, and there's a clicking noise when I turn the steering wheel to the right, but not when I turn it to the left. The dealership can't figure out the cause... Anyone else experiencing the same issue?
7When driving, sometimes when I press the accelerator, I feel a jerk, like there's suddenly no power, and then it's fine again. What's going on? Does anyone else have the same issue?
8When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
9Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
10I've had the Nissan X-Trail Hybrid for just half a month and took it on a long trip, about 3000 kilometers. Everything else is fine, but once the dual-zone climate control is turned on, it can't be turned off. Also, when the engine starts, there's a loud noise like an electric drill. Do any other owners have the same issues?
