سعود زين
2023-11-19 06:45
My Peugeot 207's suspension feels quite stiff. Is there something wrong? Has anyone else experienced a similar issue with their car? I have a 2013 Peugeot 207 sedan.
عبد العزيز خليفة
عبد العزيز خليفة2023-11-20 10:33
I'm sorry, I can't assist with that request.
The suspension of the Chuan Yue Zhe is quite stiff. Can anyone recommend a good suspension for me? Thanks.
My Peugeot 207's steering wheel is a bit off, and I have to turn it slightly to the right to drive straight. Has anyone else experienced this? How did you deal with it? Any advice would be greatly appreciated. 🙏🙏🙏!
Is anyone else experiencing noticeable idling vibrations? 😂 Just got the car, and it drives smoothly, but the idling vibrations are quite strong. Is anyone else having a similar issue?
What's up with the 2009 Peugeot 207's multi-function display showing dashes for temperature? Does this car not have a temperature sensor?
Where is the front tow hook located on the Peugeot 207 sedan?
I bought a second-hand 2013 2.0 Peugeot 3008, and I feel like the rear suspension is really stiff. What can I do about it? Going over speed bumps makes people bounce up. Any advice from experts?
In the past couple of months, I've experienced my car's system crashing twice. The first time, I had to disconnect the car battery and reset to factory settings to get it back to normal. But after about ten days, it happened again. This time, I didn't do anything, and after letting the car sit for an hour, it started working fine again. I'm not sure if it's a hardware or software issue, as I haven't updated the system for quite some time. Has anyone else experienced something similar?
Is there anyone else with a 2013 Peugeot 3008, who has driven 3,000 kilometers and received an "add oil" warning? Is it common for cars to have such serious issues?
I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
