سعود عثمان
2024-01-31 11:10
My Peugeot 207's steering wheel is a bit off, and I have to turn it slightly to the right to drive straight. Has anyone else experienced this? How did you deal with it? Any advice would be greatly appreciated. 🙏🙏🙏!
Comments( 7 )
عبد العزيز أم
عبد العزيز أم2024-03-26 10:10
First, check if the tires are worn out, then adjust the steering arm nut. I don't think it's difficult.
سعود سليم
سعود سليم2024-03-25 19:13
I had the same situation and just got it adjusted for free at the 4S shop. It's a minor issue.
محمد مسعود
محمد مسعود2024-02-10 12:11
Check the rear wheels!
خالد خلوق
خالد خلوق2024-02-10 08:30
Complete a four-wheel alignment.
أحمد طيب
أحمد طيب2024-02-02 14:39
Four-wheel alignment
حسين عبدله
حسين عبدله2024-01-31 20:31
You can try wheel alignment.
أحمد سعد
أحمد سعد2024-01-31 19:20
It's fine for driving, no need to fix it.
Hello everyone. I have an '06 Peugeot 206 with a 1.6 engine. I've been driving it for over two years now. I'm thinking about fixing it up a bit, like touching up the paint and replacing the floor mats and seat covers. I've been keeping up with the maintenance, so I won't go into that. Now I'm just wondering, given the age of the car, is it worth investing more into it? Would appreciate your advice. Thank you!
My 2002 Acr30's air conditioning has an issue. When I set the temperature above 18 degrees on either manual or automatic mode, it blows hot air, and there's an engine oil smell coming through. However, if I set it below 18 degrees, it blows cold air and the oil smell disappears. Has anyone else experienced this with their car, and how did you deal with it?
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
How do you deal with this JBL sound system? The Bluetooth connection is really bad, and using a USB drive is only slightly better. You'd think with 9 loudspeakers, it wouldn't be this bad. And there's no CarPlay amplifier. How did you guys solve this?
My Peugeot 207's suspension feels quite stiff. Is there something wrong? Has anyone else experienced a similar issue with their car? I have a 2013 Peugeot 207 sedan.
Hey folks, how long did you wait before hitting the highway? I've actually been driving for less than two months, or maybe two years. The car's been sitting back home and I'm worried it'll just go bad. Any advice from those with experience? Much appreciated 🙏🙏🙏
Has anyone successfully unlocked their car system? I'm looking to modify my car's system mainly to install third-party apps like Dudu Launcher. I'm hoping to find a tutorial on how to unlock the system's permissions without fully flashing it, as my current package is a lifetime deal, and I'm worried it might void it. Any advice from knowledgeable car enthusiasts would be greatly appreciated. Thanks! 🙏
What's up with the 2009 Peugeot 207's multi-function display showing dashes for temperature? Does this car not have a temperature sensor?
I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
