عمر آدم
2024-04-26 21:17
علي تميمي
علي تميمي2024-05-11 21:12
The keypad has been removed. Try shorting the wires to see if the button is faulty.
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
I have a Maserati Quattroporte. Recently, when parked under the sun, the AC blows hot air, but after parking overnight in the garage, it works fine again. This keeps happening repeatedly. Does anyone know what might be the cause?
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
Is the warm air blowing on the windshield of your LC120 also weak?
Is the warm air blowing on the windshield of your LC120 also feeling weak? Is it the same for you guys?
