Is the clutch on the 207 particularly high? Should I replace the clutch kit, or is this normal for the car?
[Prayers] How often should I replace the car battery???
I've reached 100,000 kilometers. Do I need to replace the clutch kit?
How can I adjust the clutch on a Peugeot 206 if it's too high?
4MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
5For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
6Is the clutch on the 207 particularly high? Should I replace the clutch kit, or is this normal for the car?
7How do I adjust the low beam height on a Peugeot 207? It's too high and keeps blinding other drivers at night.
8Is the clutch very heavy? Do I need to replace the clutch kit, or should I replace something else? Or is this normal? It's a 2014 model with over 200,000 kilometers, and I just got it as a used car.
9Kia Cerato 2018, manual transmission. I've replaced the clutch kit twice, but the clutch still feels heavy. It's almost 90,000 km now. How do you guys solve this? 😩😩😩
10Is it normal for the clutch of the 1.6 Jinxuan manual to be particularly hard?
