Is the AC not engaging related to a damaged outdoor temperature sensor? My external temperature sensor shows a dash.
Where is the MG GS outdoor temperature sensor located?
4The 2014 model with a 3.5L engine shows the engine warning light and exhaust system fault light at 100,000 km. The sensors have been replaced, but after a while, the lights come on again. Does anyone know what the reason might be? Generally, the lights only come on when driving at high speeds. Could it be related to the Evans waterless coolant that was changed a few years ago at the 4S shop?
5What's up with the 2009 Peugeot 207's multi-function display showing dashes for temperature? Does this car not have a temperature sensor?
6I got a 2011 manual 1.4 Peugeot 207 for my wife to practice driving. The car just arrived, and I have a few questions for experienced owners. 1. Does this car not show fuel consumption on the display, do I have to calculate it myself? 2. The original parking sensors make a beeping sound, but is there a distance display? Where can I find it? I couldn't locate it. 3. When the vehicle is running and I turn the key to the ignition position, there's a clicking sound. What's the issue?
7My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
8Why does my car's radiator show high temperature after driving for a while? Does anyone know the reason?
