علي يزيد
2024-04-28 16:43
Is it necessary to hold the fuel nozzle manually while refueling to prevent it from shutting off? Does this happen to anyone else?
عبد العزيز أم
عبد العزيز أم2024-04-28 17:01
Replace the carbon canister solenoid valve. It's likely that this is the issue. They cost about 20-30 bucks each.
Hey buddies! One time I braked hard and the gear shifted from D to N. Has this happened to anyone else? Is it normal? (;`O´)o
Why do I have to manually activate the Lane Departure Warning every time I drive the 2020 Jetour X90 Yingyue model? After turning it on, if I turn off the engine and restart, I have to manually activate it again. Why is this happening?
When I stop my KIA Soluto, turn off the engine, and shut everything down, after about a minute, there's a strange noise. It sounds like a locking noise, but it's not exactly that. Does anyone else experience this with their automatic transmission? Does anyone know the reason? Please let me know.
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
Has anyone experienced the car shutting off automatically while driving, and then it won't start? You can't shift gears, the car rolls by itself, and the engine warning light turns on automatically.
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
Does anyone else experience a ticking noise from the B-pillar while driving? That kind of tick-tock sound.
Hello fellow car enthusiasts, I have a 2013 VW Jetta manual comfort model. After running the AC for about an hour, the airflow becomes weak and almost stops. If I pull over, turn off the AC for a while, it goes back to normal. Has anyone else experienced this issue?
After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
