If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
Comments( 6 )
The spare tire compartment always has water in it, what should I do? Is it because the drainage hole is blocked or is it an issue with the wiring of the installed reverse camera?
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
I just went to the 4S shop today, and I can't upgrade the car system. The original 360 camera is not clear and can't be calibrated. Regarding the transmission defect issue, the after-sales service at the 4S shop will apply to the manufacturer and get back to me. Also, I'm wondering if just changing the DSP will improve the original audio system since I don't like it. I'm considering the Pioneer 500A, which can connect directly with the original plug without installing separate loudspeaker wires.
4If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
5Hey Alto friends! After I connected the reverse radar wires myself, the car started twice without any issues. But after I arranged the wires, it won't start anymore! Does anyone know what might be causing this?
6I'm looking to install a central control screen with a reverse camera on my 2014 Peugeot 301. Any recommendations, fellow car enthusiasts?
7Is there anyone experienced with installing a 360-degree camera? Could you please tell me where to find the turn signal wire? I've been looking under the driver's side and can't find it. 🤣
8I recommend looking for a phone holder that is compatible with your 2019 GWM GS5 Automatic Luxury model. A good option would be a dashboard or air vent mount, which provides stability and easy access to your phone. As for placement, many people prefer to mount the phone holder on the dashboard or near the air vents, as it allows for a clear view and easy reach without obstructing your view of the road. Regarding the CarLife connection issues, it might help to check for any software updates both on your phone and the car's infotainment system. Also, ensure that the cables and ports are in good condition, as wear and tear could cause connectivity problems.
9There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
10I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
