محمد إسماعيل
2024-04-01 18:15
I got a 2011 manual 1.4 Peugeot 207 for my wife to practice driving. The car just arrived, and I have a few questions for experienced owners. 1. Does this car not show fuel consumption on the display, do I have to calculate it myself? 2. The original parking sensors make a beeping sound, but is there a distance display? Where can I find it? I couldn't locate it. 3. When the vehicle is running and I turn the key to the ignition position, there's a clicking sound. What's the issue?
عبدالرحمن بهاء الدين
عبدالرحمن بهاء الدين2024-04-02 13:49
1. Do it yourself 2. Can only judge distance by rapid sound 3. That's the sound when you turn the key after starting the engine
عبد العزيز أم
عبد العزيز أم2024-04-02 09:09
1. Press the button on top of the wiper switch to toggle. 2. The faster the sound frequency, the closer the distance—just imagine it. 3. For the "da da da" sound, it's recommended to send a video for assessment.
Can anyone help me? Why is there no sound when I insert the USB drive, even though there's a display? Thanks 😊
Guys, I've got a problem! Sometimes when I go through the underground parking lot, I hear a "beep beep beep" sound. I check it out and find it's my car making the noise, and the yellow light flashes rapidly. The sound stops after about 10 seconds, but the yellow light keeps flashing for several minutes. It's happened more than once! Can anyone tell me what's going on? Can I turn it off? It's pretty annoying for others too.
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
I'd like to ask fellow car enthusiasts about the fuel consumption display of the Scirocco when cruising at a steady 120 km/h on the highway during the Spring Festival. Please specify your model, like 1.4T single turbo 7-speed showing xxx fuel consumption at 120. I'm just looking for a reference because I'm considering buying a fuel-efficient car with cruise control for highway driving. I think the Scirocco 1.4 single turbo is pretty good, but I've heard that the 2.0T 6-speed is also very fuel-efficient.
My wife bought an 18-year-old used car, and today I drove it for a few dozen kilometers. I have a habit of occasionally resting my hand on the gear shift. When I did that, I noticed an issue. When shifting from second to first gear, I felt a slight "ka-ta" sensation! The sound is very faint, and you probably wouldn't notice it without your hand on the gear shift. Is this indicating a problem?
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
Has anyone experienced issues with the radar not working? I recently noticed that when I turn on the radar, it beeps three times, and then there are no distance alerts. Is it broken?
I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
It seems like there is no automatic high beam feature, and when reversing, there is distance display and a warning sound. It doesn't seem to have automatic braking. Is it because the reversing speed isn't fast enough?
